Silencing options
typical10
Silencing options
Post by typical10 » Sun Nov 26, 2017 7:41 am
I see that excalibur has a a new bow with a number of limb, and string devices. What do you recommend for not spending cash on so so options. Going on a new Matrix 380 blackout. Thanks Jeff Haugland~
Re: Silencing options
Post by vixenmaster » Sun Nov 26, 2017 7:52 am
I fer one don't put much on my Excals but others load theirs up. On the short limbed models i have a set of bumpers n thats it
crossbowcrossroads.com/forum/
Marie Laveau Voodoo Queen Matrix 360 Utahraptor Scorpyd DS
Pipsqueak Hybrid Micro/Matrix 135 lb 235 fps Banshee MXB320
bigbowman
Post by bigbowman » Sun Nov 26, 2017 8:13 am
I agree! I’ve loaded my bow up with the S5 String Suppressors, rubberized the stirrup, rubberized the arrow retainer, Ex-Shox and a Flemish string. The only one that I noticed that made any difference was the string stops! They reduced the string oscillation and vibration. Crossbows will always be loud to the human ears, it’s just the nature of the beast! Good luck!
Black Eagle Zombie Slayers
Black Eagle Executioners
NuFletch Archery "Ignitor" Lighted Nocks
NAP Swingblade, Rage Hypodermics and Shwackers
ch312
Post by ch312 » Sun Nov 26, 2017 8:57 am
Attempting to quiet a crossbow is pointless for hunting purposes and can actually have a negative impact with the increased weight of the bow working against the shooter in offhand situations. What it comes down to is personal preference and how much money you want to spend so it's up to the individual to decide what's "worth it" to them.
On my old bow I wasted a bunch of money on sound dampening products and in the end there was zero difference from the deer's perspective, but there was a noticeable difference in the perceived weight of the bow as it was front heavy. My Bulldog has the S5 system, nothing else.
Post by longbow joe » Sun Nov 26, 2017 10:20 am
X2 the s-5 and a set of catwhiskers for the string . You have to wire tie both sides of the knot with micro wire ties and the knot will stay tight. The catwhishers are about the only thing that actually makes a difference .....and the cheapest. The dr stririp bumpers are really tough and fit on the s-5 posts they seem to help a few percent.
After these cheap mods l forget about the noise.
Post by Boo » Sun Nov 26, 2017 11:15 am
Temper what you read with the fact that noise and noise level is subjective. It is not the same to everyone and certainly holds true to whether or not it's worth it. Keeping in mind that most of us here are no spring chickens :mrgreen: and add to that many professions and hobbies (shooting/rifle hunting/handgun shooting) has robbed many of us of our hearing, so don't be deterred to try or experiment with things that work for you.
While you'll never make any bow a silent deer killer, you'll make the bow more pleasurable for you to shoot. The only real plusses is that a more quiet bow may not spook other deer further away and generally, the more silenced bows will show less jump/shock on the shot which will let you see you arrow hit it's mark. Watching your arrow through the scope is invaluable to more accurate shooting.
Si vis pacem, para bellum
Correct a fool and he'll hate you, Correct a wise man he'll thank you!
Madness is having a Malinois
Boocustomstrings.com
LongCarbine
Post by LongCarbine » Sun Nov 26, 2017 11:32 am
I could not agree more . When I first got my crossbows it was hard to see the arrow hit the target ,but after I tamed it a little I can see my arrow with no problems .
Axiom (Alum.Rail)
Matrix B.D 330
tipnchip
Post by tipnchip » Sun Nov 26, 2017 2:33 pm
You will never quit your bow as fare as a deer is concerned. I blew a shoot this year because of noise.
Had the deer ranged at 35 yrds. when I flipped the safety off on my matrix 330,uasally I easy the safety off. At any rate it had a slight click to it and the deer came alert at the sound and wasted no time walking back into the woods.I do have bumpers and camo tape on the limbs. The tape was mainly for sun glare. Would like to do some thing with the stock to but I don't think the tape would hold and I don't want to paint. I know set in the shade but that is not always possible.
Post by gerald strine » Sun Nov 26, 2017 3:20 pm
All valid opinions offered here but I just go with the bumpers my self I got used to the noise and it is about the last noise the deer ever hears.
mikej
Post by mikej » Sun Nov 26, 2017 3:34 pm
How did you rubberize the stir up and bolt retainer ?
Post by gerald strine » Sun Nov 26, 2017 4:10 pm
I forgot about the stir up I wrapped mine in tire inner tube rubber and then in cloth camo tape not a big difference in sound but it also protects the stir up.
Post by Boo » Mon Nov 27, 2017 10:41 am
This is a good illustration of a lower chance of a score. If an alert deer comes in, your chances of nailing it is lower. Your percentage goes down even more if it is looking at you and you take the shot, it will see limb flex and visual alerts are far more alerting than noise. Predators don't make a whole lot of noise when they launch at their prey but the movement cannot be helped. Your best percentage is a calm deer, looking away, ears pointing away and busy doing something like eating or smelling something.
BTW, keeping pressure (pushing forward) on the safety lever while pushing up shuts up that click.
Post by Boo » Mon Nov 27, 2017 10:50 am
Mike, you can buy a can of truck bed spray on liner or go to a shop that sprays on truck bed liners. The arrow retainer is more easily dealt with using double wall (self sealing) heat shrink tubing. Any electrician will have what you need.
nchunterkw
Post by nchunterkw » Mon Nov 27, 2017 12:23 pm
I do not like to do anything to my bow that costs me arrow speed without giving me anything in return. As such, I only use a Flemish string, a heavier arrow (which does the most) and the string bumpers. The heavier arrow costs me speed but give me more arrow momentum which translates to better penetration so I view that as a good trade. The others do not cost me any speed. But it's all personal preference.
"Nothing clears a troubled mind like shooting a bow."
Micro, Vortex
RamCat, Slick Trick
BE Zombie, GT NitroPro
2" TF Feathers, Trinity Strings
[email protected]
Users browsing this forum: bigbowman, DMc, dropzone, Google [Bot], Jim M and 136 guests
