Replacing REDS
colouredchameleon
Location: The Land of the Greatest Crossbow Made - Excalibur's Canada
Re: Replacing REDS
Post by colouredchameleon » Mon Dec 25, 2017 1:39 pm
Here in Kingston over the next week it will drop to as low as Minus- 29 deg C.
I suspect if you see similar temps you may be able to place the crossbow outside foe enough time that the cold may may cause just enough metal contraction to allow it to free up.
xpert1111
Re: Replacing REDS
Post by xpert1111 » Tue Dec 26, 2017 8:43 am
Going to try again this week. These things don't budge at all
Re: Replacing REDS
Post by xcaliber » Tue Dec 26, 2017 8:48 am
Set screws are removed, correct? Maybe put some penetrating oil in the holes and let it work for a few days.
Matrix 380 (Max) Leupold Crossbones
xpert1111
Re: Replacing REDS
Post by xpert1111 » Tue Dec 26, 2017 8:56 am
Yes of course. I'll try the oil suggestion
Re: Replacing REDS
Post by flightattendant100 » Tue Dec 26, 2017 10:20 am
Pad vice grip jaws w leather, grip stud where rubber was, tap on vice grips w hammer. Maybe a slight twist w vice grips. This will let you get them out and shouldn't harm anything.
L. E. Carroll
Re: Replacing REDS
Post by L. E. Carroll » Tue Dec 26, 2017 2:42 pm
If nothing else works and your season is over ? Perhaps send the riser only to Danny Miller, or if living North of the Border ? back to customer service at Excal and they may be able to get them out with no damage to your riser.
All it would take is a phone call to Dawn or Danny to see if that could be a option for you.
Just a thought. :idea:
However, If it was me, having used DR bumpers with the Excal posts on one of my Micro 355's, ( that's the way they are designed to be used) I would definately forget about removing them and go that route.
Gene
Camo Micro 335 gen. ll " w/ XB30 SR Pro
Camo Matrix 380 W/ Crossbones scope & a Boo trigger
all w/Camo Munch mounts
Sweet 44 yr. old 73 Bronco
Scamp tralier
xpert1111
Re: Replacing REDS
Post by xpert1111 » Tue Dec 26, 2017 5:44 pm
Exactly what I did after spraying PB Blaster in the set screw holes and letting it sit for several hours. FINALLY came out. Thanks all for the help and suggestions!
Re: Replacing REDS
Post by flightattendant100 » Tue Dec 26, 2017 6:08 pm
:D :D :D Some times you tap it.....Some times you TAP it!! Glad you got it. Its one of those "it feels good since its quit hurtin' "deals.
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 74 guests
