Check this out!
Re: Check this out!
Post by paulaboutform » Sun Mar 04, 2018 11:02 am
You make a good point Paul. I use a level on the riser, mainframe and a plumb line when scope leveling. I also use a scope level as well as the riser level...and as Paul said, the riser level is usually out. However, it is consistent and I believe closer than the naked eye therefore worth using. Eg, on my Frankenbow the scope level is true but the riser level shows a slight cant to the right side of the bubble and I know I'm level. If you're using a level and find your arrows are drifting low left or right at further distances, try canting your bow slightly left or right and watch your arrows come back to center.
Stab 'em
Re: Check this out!
Post by Stab 'em » Sun Mar 04, 2018 2:04 pm
I got a couple of different types of camera levels off eBay. After leveling up the bow with them and a long carpenter level on the limb tips I put scope level on the scope mounts, to match the other bubbles. The scope level is right in my peripheral vision where it needs to be.
Users browsing this forum: Baidu [Spider], Bing [Bot], Majestic-12 [Bot] and 56 guests
