What arrow weight do you prefer?
What total arrow weight do you prefer using in your crossbow?
350 grains
28
9%
375 grains
40
12%
400 grains
138
42%
425 grains
70
22%
450 grains
24
7%
475 grains
10
3%
500 grains
5
2%
525 + grains
10
3%
Total votes: 325
bhayward
Re: What arrow weight do you prefer?
Post by bhayward » Fri Nov 18, 2016 8:58 am
450 shoot real good groups out of the bulldog
crabclaw
Post by crabclaw » Sat Nov 26, 2016 4:49 am
Chose 400,
Big John customs weigh in at 412
Equinox
Ibex
Big John custom bolts
slick tricks
williams
Post by williams » Thu Dec 29, 2016 3:57 pm
Always around 450 for me and I always use 150 grain bolt cutters shooting perfection from my micro 355 and my older vortex . Zombies 16.5 inch lumenok 110 brass insert and 150 bolt cutter 20 inch GTLAZER 2 110 insert lumenok and bolt cutter. Executioner 18 inch 92 insert lumenok and bolt cutter.
76chevy
Post by 76chevy » Mon Jan 16, 2017 2:35 pm
I shoot the stock bolts in my Matriz Grizzly with a 150 field point or slick trick. Not sure what they weigh but they seem to shoot great!
Any suggestions on other combos to try for this bow??
racking up points
Post by racking up points » Fri Jan 20, 2017 10:48 pm
76chevy wrote:I shoot the stock bolts in my Matriz Grizzly with a 150 field point or slick trick. Not sure what they weigh but they seem to shoot great!
Check the pages of forum member arrow recipes in the sticky threads above/below this one. Happy reading
bowman81
Post by bowman81 » Sat Jan 28, 2017 9:17 am
I build my arrows, they come in at 397-400 gr. with 125 grain heads. I only hunt whitetail deer and they give a good combination of speed and penetration for my purposes.
I use 20" for my Axiom and 18" for my Matrix 355....both sets of arrows weigh the same.
Big John
Post by Big John » Sat Jan 28, 2017 10:32 am
Most can see there is a lot of testing and results using a standard arrow combo. Yes anyone can manipulate it anyway either direction in weight, but this combo seems to be the average that gets best FPS, FOC, and Accuracy from most Excalibur Bows. If one were to use this formula in any bow from Excal they would achieve very good results.
Any arrow you chose.
92 to 110 gr. Brass front inserts
100 to 125 gr. Heads
That's up front weight of 192 gr to 235 gr.
How you get the up front weight is up to you.
Adding a Lumenok will not affect accuracy with this either.
If you use the arrow length given for each bow and this weight forward calculation, you arrows will fly great!
Especially if you have a good Helical on your fletch.
Adding more will result in more loss of speed.
But, it will quiet your bow down.
Big John
Arrowmaker - Retired
[email protected]
roseawebs
Post by roseawebs » Fri Feb 10, 2017 3:52 am
I always select low arrow weight. It more flexible than high weight arrow.
I will select 400 grains.
GWW
Post by GWW » Fri Feb 10, 2017 1:48 pm
I'm shooting Wyvern's Micro 355 arrows, which are 16.5" BEE's at 400 grains. They shoot very well in my Micro 355.
GWW
09 Equinox
Varizone
OldWolf
Post by OldWolf » Sat Feb 11, 2017 12:01 pm
I have 18" Diablo arrows with Lumenoks, helical blazer vanes and 150 gr tips. They weigh in at 418 grains. I'm in between but I guess 425.
Those who are brave .. are free.
Grizzly
HHA Optimizer with Hawke Scope, Munch Mount, Quikee 3 quiver,
BowJax2 silencers, self made kydex cheek piece
18" Diablo Arrows w Blazer vanes, 150 gr Boltcutter BH's, Lumenoks
418 grains with 16.66% FOC
Opa
Post by Opa » Sat Feb 11, 2017 12:35 pm
I am new to crossbows-I ordered the Bulldog Suppressor 400- I plan on using the recomended diablo 250 grain with the 150 grain bolt cutter. I typically stick with what the manufaturer and the experts say. I have always shot mechanical with my PSE Fire Flight compound. I just hope the fixed bolt cutter flies good. Any advice is appreciated,
Marion
Post by Marion » Wed Mar 01, 2017 6:34 am
vixenmaster wrote:Peter afternoon, i prefer 500gr on up to 650gr arrows fer my hunting. I cast my vote at the 525+gr
What type of speeds are you getting out of your vixen with a 500gr.. That's what I plan on shooting
Thanks!!
Marion
Post by Marion » Wed Mar 01, 2017 12:16 pm
Buszone wrote:Vixen at 625gr. those are not arrows those are flying logs :lol:
What speed are you getting @ 625?
outdoorsman
Post by outdoorsman » Sun Mar 12, 2017 7:42 am
Iam using 393gr with broad head
16.5 zombie slayers
Micro suppessor
nchunter
Post by nchunter » Thu Mar 16, 2017 5:58 pm
I made a pretty radical change last hunting season that may be of interest to some:
For the last 15 years my set-up was 100-gr Rocket Hammerhead expandables with a total arrow weight of 425 grains. I've harvested about 35 deer with this set-up, using my 2001-vintage Exocet. Velocity is 273 fps.
Last hunting season I switched to Centaur Battleaxe Broadheads. These are enormous, 242-gr two-blade, single-bevel fixed-blade heads that appear ridiculously over-sized at 2 inches wide. And my total arrow weight now is 577 grains! Velocity is 249 fps.
Sounds (and looks) crazy, but by fletching with 2" Blazers or Quickspins at the maximum LW Helical that my fletching jig allows, these over-sized heads actually group with field points out to 40 yards.
I took three deer with these last season. I got complete pass-throughs in every case, no matter what bones were hit. In one case the pass-through was length-wise! And the blood trail is instant and profuse.
I now can do straight-down spine shots at deer directly under my stand and get a pass-through heart shot. I could never risk that shot with a conventional expandable broadhead.
Users browsing this forum: Bing [Bot], GrassyKnoll, Majestic-12 [Bot] and 56 guests
