Arrow and Bow combinations of forum members
rein1
Re: Arrow and Bow combinations of forum members
Post by rein1 » Sun Dec 04, 2016 4:11 pm
amythntr wrote:PROPER BRACE HEIGHT ON THE BD400:
FROM A PREVIOUSLY POSTED THREAD:
I've read on here where Peter from Excalibur says 2" from the rail/riser connection will give you the fastest speed from the Bulldog..
You definitely want enough brace height to where the string is not sitting or pushing into the REDS... Most I believe prefer about an 1/8" - 1/4" off the bumpers..
Peter is correct. I've tested above, at and below.
SEW
What happen to ??
Quote :
Hi sonny .... This post is for the general CB thread not really for here... This is for people to list their combinations and Recipies ....
Anthony :)
Post by vixenmaster » Sun Dec 25, 2016 10:25 am
Custom Matrix 360, BEE's 400gr RH helical 18"
crossbowcrossroads.com/forum/
Marie Laveau Voodoo Queen Matrix 360 Utahraptor Scorpyd DS
Pipsqueak Hybrid Micro/Matrix 135 lb 235 fps Banshee MXB320
MI Yeti
Post by MI Yeti » Tue Dec 27, 2016 1:02 pm
late 90s Excalibur exocet 165 . 20" Gold tip laser IIs, 4" vanes, brass inserts, aluminum nocks, 125gr muzzy three blade . I have been wanting to go to 100gr broad heads but the cost and the fact these shoot very well have kept me from doing it .
Exocet 165 2.5x32 Drop Zone scope
Vixenmaster and Danny miller strings
Gold tip laser II arrows ,Muzzy broadheads
williams
Post by williams » Wed Dec 28, 2016 9:18 pm
With my Vortex I shoot 20inch GT lazer 2 with110 brass insert lumenok and 150 gr boltcutter. Around 450 gr arrow very accurate. I have a micro355 I shoot 16.5 inch zombies 110 brass insert lumenok 150 gr boltcutter around 453 gr total . I love the accuracy of these crossbows cant shoot the same circle twice . I also used a 18 inch executioner with 92 gr insert lumenock and 150 gr boltcutter on 355 around 447 total weight shoots just like the zombies didn't have to mess with the scope.
Predator55
Post by Predator55 » Wed Jan 04, 2017 10:50 pm
I have a grizzly cub, shooting the stock arrows it comes with and a 150 wensel woodsman, shot a deer the other day, first with the crossbow and at 30 yards, complete pass through and left the broadhead in the tree, took the arrow. I also use 2219 cut to 17 in with alum flat nock and a woodsman 150 gr head, total weight is roughly 450 gr and hits to the same poi as the carbons that weigh 350gr. Sighted in the stock three dot the bow comes with and it will hit a dime at 50 yards, love the three dot too, very fast shooting scope.
OldWolf
Post by OldWolf » Fri Jan 20, 2017 2:51 pm
Matrix Grizzly
18" Diablo Arrow, blazer vanes fletched with Ariz. EZ Bolt
150 gr Boltcutters
Lumenok lighted nocks
Total weight 418 grains
FOC 16.66%
Those who are brave .. are free.
Grizzly
HHA Optimizer with Hawke Scope, Munch Mount, Quikee 3 quiver,
BowJax2 silencers, self made kydex cheek piece
18" Diablo Arrows w Blazer vanes, 150 gr Boltcutter BH's, Lumenoks
418 grains with 16.66% FOC
Huntin with bulldog
Post by Huntin with bulldog » Sat Jan 28, 2017 2:51 am
Bulldog 400
18" diablo
175 grain veteran broadheads
Lumenock
Total weight 451grains
Not as fancy as some of yours but it works !
GWW
Post by GWW » Fri Feb 10, 2017 1:55 pm
Micro 355
16.5" BEE's
110 gr. Inserts
2" Blazer vanes
Lumenocks
100 gr. Shuttle T-Lock broadheads
Approx. 400 grains
GWW
09 Equinox
Varizone
kjl
Post by kjl » Tue Feb 28, 2017 11:44 pm
Micro suppressor
16.5 " indexed Black eagle zombie slayers .001
110 grain inserts
Blazer vanes
125 grain ramcats,125 grain field points
Lumenocks
432.4 grains total weight
Speed dial set at 315 fps
2 3/4 " groups at 60 yds using a rest 20km/hr crosswind.
micro suppressor
Ramcat broadheads 125 grain
.001 Black eagle zombie slayers 16.5 "
110 grain inserts, blazer vanes and lumenocks
Marion
Post by Marion » Mon Mar 06, 2017 9:25 pm
vixenmaster wrote:Vixen 1996 2216 XX75 628gr total arrow weight, 2" Blaser vanes 100gr heads
How are you getting 628 with 2216's. I'm using 2219 @ 20inches and only get 503 with 150gr points??
How do they fly @ long range?
Micro.slayer
Post by Micro.slayer » Wed Mar 08, 2017 7:35 pm
Bolts for Micro 335
Carbon Express Maxima Blue Streak (2) 5 packs 20"
Cut (5) to 16.5
Cut (5) to 18"
I will be using 125 gr. Ramcats for hunting
Jerry at South Shore told me to get 8/32 all thread
3' cut into (10) pieces 3" 100gr. Each
Cut slit in rod to install in insert w/ 2 part epoxy very small screw driver
End up 225 point weight chrono at 292 bolt velocity
Extremely accurrate
Micro.slayer
Post by Micro.slayer » Wed Mar 08, 2017 7:37 pm
I think m arrows C E weigh 465 gr.
Micro.slayer
Post by Micro.slayer » Wed Mar 08, 2017 7:48 pm
Sorry forgot my F. O. C. Is 17
wildcatter
Post by wildcatter » Thu Mar 30, 2017 9:27 am
wow,, another loooonnnnggg post,,,, :mrgreen:
380 MadMax:
18" spine indexed and matched Zombies
110 grn. insert
2" Blazers
D2 Firenock's
100 grn Viper Trick
410 grn total
380 Lynx:
18" spine indexed and matched dbl. wall Spynal Tapps
125 grain insert
2" Blazer
D2 Firenock's
175 grn VPA 3 blade
517 grn total of no stoppem power!
350 Matrix custom:
55 grain Loc N Load insert
2" Blazer
D2 Firenock's
125 grn. Slick Trick
395 grn total
355 Suppressor & 335 Micro:
16.5" dbl wall Spynal Tapp
80 grn insert
2" Blazer
D2 Firenock's
100 grain Viper Trick
380 grn total
Add lights (light circuit, shock collar, and battery) to any of these and weight goes up 25 grains! But these all will shoot 1" or less at 50 yards.
Hunt Hard or Stay Home!
380 Mad Max, XB-30 Pro 18" SSAS 175 VPA
380 Lynx, XB-30 Pro, 18" SASS 125 grn. S.T.
350W Custom, XB-30 18" SSAS 100 grn S.T.
Toxin 150 Custom Rangemaster Pro 22" B.E.E.
Post by xcaliber » Thu Apr 06, 2017 6:49 pm
Well, I went on a bit of quest for another forum brother and decided to evaluate the "APE" crossbow rig. This system allows you to change any vane in the field with exact results. I did not need this system, but tried it none the less. It increases your overall weight, and rear weight to be specific. End of the trial I wound up at around 9% FOC, and total weight at 524 Grains. I like the setup enough to continue the trial through the summer with both Matrix Models, and hunt as well with them, God willing. I recommend this setup for the folks that want an easy to build arrow without special tools, they hit very hard i might add.
Micro 355 (Jinx) Crossbones. TT Single Stage, Munch Mount
My own Killer Strings and Arrows.
Users browsing this forum: No registered users and 34 guests
