Euro mount 2016 buck
Re: Euro mount 2016 buck
That's quite a collection!!
2016 Matrix 350LE, Munchmount, RBB, Hawke XB1
Wolverine, Munchmount
X2 on the nice
MIcro 335 GEN 2
Widow Maker/ Undertaker
Nchunterkw Strings
Vixenmaster Slave Stringer
Cabelas Laser Stricker 11 Broadheads
Nchunterkw Strings
Nice collection.
- one shot scott
Looks like you spend more money on bleach then Pam Anderson.
And speaking of Pam, shed be pissed if she saw your collection, which is why I am so envious. Good work!!
Strong work Jeff! Very nice indeed!
Looks great ,Jeff!
Marcel
Marcel
Micro suppressor 355
Boo string force 10.
Drstirrup complete kit.
Marcel
Marcel
Jeff,
Could you share with us what hair dye or bleach you used and where you can buy it in Ontario?
I have semi-finished euro mount that I need to bleach.
- Carnivorous
YepFazan wrote:Jeff,
Use 40 volume hair dye. This can be bought at any beauty store. You have to know someone with a license to buy goods from the beauty store.
Buy enough to soak the entire skull. I like to soak for a min of 5 days for that ultra white look..
Applying a bit of heat helps to speed the process too.
I buy mine at any beauty salon, I also mix it with toner. The same way you would bleach your hair.
The lady at the salon asked me what I was doing and I told her " how do you think I keep my hair so white"
Wouldn't a cheap bottle of hydrogen peroxide mixed with water do the same thing?
Reg. peroxide is 3%, I would amagine that eventually it might work but would take forever. The 40 volume is 40% you need to wear gloves and mask off anything you don't want to bleach, mainly the horns.
I have a plastic tray I do it in and also put a heat lamp on it.
Thanks for info.
This look great!...How are you fleshing them??
- Carnivorous
Skin and remove as much meat as possible.MTBighorn wrote:This look great!...How are you fleshing them??
Boil (outside) the skull with a drop of dawn detergent 4 to 6hrs. Pick away any remaining meat and blast the brain matter out with a hose.
Let dry and soak in 40 volume hair dye for 5 days adding a bit of heat helps too...
It's a bit of dirty work but worth it IMO...
How much of Volume 40 you need to cover the whole scull?
