moles in my yard
hatchet jack
moles in my yard
,,, how do you get rid of moles in my yard,,,i have tried everything no luck,,,,,have not tried nitro yet. one of you guys know how, to get rid of those critters.
h.j.
h.j.
Woody Williams
hatchet jack
if your yard is not big ... try the spinning thing you can buy ie sunflowers, men that look like they are running ect ect ... the vibration that runs down the steel stake drives them nuts .. they will leave area ...... there are 3 differernt kinds of grubs.... 2 will already be beyond chemical control the other will be going down deep into the grass soon ... i would wait till next year , as soon as you see the first june bug hit your lawn with diazon or sevin .. there is one product that is expensive but works wonders..it is called MERIT it is made by bayer ... i dont know if people without pesticide lic can buy it or not..... those are your only choices ... but i would but the windmills in my yard to stop some damage... they look dumb but work
I don't know about the peanut butter, but you should be able to knock them off with snap traps. Moles will tunnel through the grass, set up some snap traps in their tunnels and I would be very surprised if you dont get any.Deer Dave wrote:peanut butter on a mouse trap?
The lads with the grub suggestions are right too. This would be a primary cause of the problem.
I'm in the killing business myself.
They used to have these big metal spike traps that you place in their tunnels in the grass. Man, they looked mean, I never got to see any work though - maybe before my time.
Good luck.
150 lb Wolverine
165 lb Exocet
175 lb Phoenix
165 lb Exocet
175 lb Phoenix
The Pistoleer
Best way is to use a spiked mole trap. I found a picture on one on the net at one time; my dad made one and it worked great. Found one here
http://www.northerntool.com/webapp/wcs/ ... cs&afsrc=1
Place over existing tunnel, jam spikes into ground to make sure they can penetrate and load. If it is triggered, do not remove spikes, dig it up or block his tunnel first. You don't want to let the little sh!t go!
This works for ground hogs also, you do not have to chew it though, just put it out and in your case in the tunnels, they eat it but can't digest it and it blocks their system up, a little cruel I think but it works is the bottom line....pdislow wrote:while you are trying different stuff, try chewing up a piece of juicy fruit chewing gum just enough to make it look like a slug, and place it in one of their trails. when they eat it it is supposed to killem.cheap and easy and it may even work. good luck!
