Targets?
Targets?
Just got an Exomax with Varizone scope and I can't shoot it. The dealer said I shouldn't use The Block, and that I need to buy a target designed specifically for crossbows. I can't find one locally, but I have found them online. I can't sit around for a week with this Exomax and wait for FedEx. I've got to shoot this thing at something, I can buy another dog but my wife would kill me, or even worse take the Exomax. Does the target really matter?
crazyfarmer
hawg hunter
targets
wally world sells a target that will stop bolts with field tipsand it reasonably priced. rhino sells the best crossbow target on the market for use with field a broadheads.
xChrisx this should work for you.
Take all the plastic shoppping bags that you can find and stuff them very tightly into another bag. This infront of the block (dirrectly against) should give you enough resistance to stop the max if the block does not stop the arrow on it's own.
Remember to make sure the path behind the target is safe incase the arrow passes through the target.
Good luck and enjoy.
Tom
