well I got the box today, and had what you see in the picture. I guess the brass inserts go on the broadhead end as the broadhead don't fit the aluminum ones. I was not told I had to put them in....I was to dumb to ask , guess that is what a guy gets for assuming.
My question is>>> is there a special glue that is required. or will a HOT GLUE gun (like the wifey's) work. as they seem to slide in shaft fairly loosely.
You help is again appreciated.
