arrow diameter
arrow diameter
i've drcidewd to make my own arrows. 2219 at 16" length. they will weigh out at about 346 grains. is the diameter the same as GT lazer ll. i'd sure like to be able to use those nocks again.
"Be on the alert,stand firm in the faith,act like men, be strong."
Diameter
When you are looking at a bolt designation i.e 2219, the first two numbers are the number of 64's for outside diameter and the second two numbers are the wall thickness!
2219=22/64 outside diameter (0.343...") x 0.019" wall thickness!
Hope that helps!
Hope that helps!
Enjoy the Harvest!
I have measured Laser II's, 2216's and 2219's. They measure around .343 give or take a couple of thousandths. For all intents and purposes the OD is basically the same. That could just be my calipers. I have used the laser II nocks with 2216's (xx78 Super Slam alloy) with no problem. Haven't tried them on the 2219's as I don't shoot them much. I don't know the wall thickness of the laser II's but it's probably close to the 2216s. I'll mic one the next time I break one. Just as an aside the Easton Power Bolts/Beman thunderbolts measure .345 give or take. Again don't know the wall thickness but probably thicker than the Laser IIs as they are a good bit heavier. Hope this helps
Regards
Joe
Regards
Joe
Here you go!
GOLD TIP LASER BOLT SHAFTS , LASER II FLETCHED Bolts
Like our proven arrow shafts, Gold Tip’s cross bow bolts are the toughest most accurate bolts available. Our unique insert system provides increased front of center balance and overall weight for the ultimate in accuracy and durability. With the same outside diameter as a 2216 aluminum bolt, the Laser II is the ideal replacement for cross bow shooters desiring enhanced performance.FEATHERS ADD 5.00 Avaliable in 20" or 22" with flat or moon nocks
Tech Specs
Straightness............+/-0.005 inches Length
Inside Diameter.......Shaft.......0.300 inches
Outside Diameter....0.344 inches.....Spine....300....Shaft Weight......8.6 Gr/inch....Length....20" or 22"
Wall thickness would be .022", I guess a true designation would be 2222!
Yes they are the same diameter on the outside but they are not the same diameter on the inside!
The GT Laser II is .300" inside diameter.
The 2219 are .343"-(2x.019")=.343"-.018" which =.305"
So the GT Laser II are .005" smaller on the inside which would make the 2219 nocks a little tight to insert most likely!
Tech Specs
Enjoy the Harvest!
arrow diameter
One thing to take into account is FOC when you change length of bolt.
If you have the same weight of nock,same length and weight of feather or vane,and the same weight of insert,and you shorten the bolt,you will change the FOC.
In a shorter bolt,in my opinion,FOC is far more important.
You may need to increase the weight of your target or broadhead tip to a
125 gr,from 100 gr,for starters.
Just MHO.
Just MHO.
Bob Vandrish.
