Wedged Vixen Setup, Trying photo bucket, first time.
curmudgeon
Post by curmudgeon »
Imagehttp://s299.photobucket.com/albums/mm
Image Hope this works.Image
Distance was 51.5 yards @ 303 FPS. Shrink fletch tapered bolts with 100 grain field points. Now to try my practice Muzzy's.
curmudgeon
Thanks Bob, I'll give that a try. Nice Welder.
curmudgeon
Bottom target with the two holes that are from my Omega.
frisky
Post by frisky »
Looks like you killed your target...
2007 Phoenix
Custom Wood Stock
Gold Tip II 311 Grain
Boo Astroflight String
Varizone Sighting
mikej
Post by mikej »
what are those additions you've made to the vixen looks like some form of sts . and by the limb tips? ... foam?
curmudgeon
Thanks BOB, I know slower will do the same job and is quieter. Near the limb tips are mole skins to quieten the slap of the string and I use (L) brackets with Simms Limb Savers attached to the straighter riser. I have a newer model Vixen that has not been modified. The fletching is Quick Spin Shrink Fletch.
Thanks for your comments. :D
tuskntine
Post by tuskntine »
How much could the mole skin actually slow the speed down ? I have a 2007 Phoenix and I am fixing to add spider legs to the string and will try the mole skin also . I don't want to sacrifice TOO much speed but quiet is good too .
Love your neighbor, but keep your guns oiled.
warningshot
Post by warningshot »
hey curmudgeon...can you take a pic of you xbow from the top ...i'd like to see your setup....with the L brackets ...thanks
fogducker
Post by fogducker »
warningshot wrote:hey curmudgeon...can you take a pic of you xbow from the top ...i'd like to see your setup....with the L brackets ...thanks
i,ll second that motion...
also whats the big knobs at the bottom of the said bracket for?
