Scopes
Vortex in SD
Scopes
Post by Vortex in SD »
Currently I have the open sights on my Vortex!! The question is that I'm looking at possibly adding a scope on :) :)
In South Dakota the scope can not have any magnification-- so just a 1x I know that is it!!
Any thoughts on scopes would be much appreciated :D
Thanks,Dean
awshucks
Re: Scopes
Post by awshucks »
I like the peep and pin, use mine every y ear for turkey season. Given the choice between it, red dot or 1x, I'd stick w/ it. I sight my pin for 20 and the black post under it is good for 30.
I did experiment w/ a Chinese halo, NCStar, but it was only marginally better than P&P, imho. $49, if I recall.
theoldarcher
Re: Scopes
Post by theoldarcher »
I like hunting with the fiber optic peep and pin as well. I killed three with it this past season out to 30 yards, no complaints. I did however try this last year with my Phoenix.
http://www.truglo.com/IW_Products.m4p.p ... TEM_SUBMIT
I liked it real well and kept it till I got rid of my Phoenix.
Truglo 4 dot red dot
Cossack
Re: Scopes
Post by Cossack »
If ppes aren't for you, Traditions makes a 1 power scope for MLs that may meet you needs. I like the certainty of a cross hair rather than having to depend on a tiny battery. That said TruGlo makes a small reflex sight like the one pictured above that has 4 dots, whose spacing can be changed to correspond to the trajectory of your bow.
Incurable tinkerer.
rt2bowhunter
Re: Scopes
Post by rt2bowhunter »
I have tried several scopes. I like the holo type sights. I hunted all season with one and hunted a lot. Still using the same battery.
i have the sightmark on my Ibex. I just turn the dial in between settings (its off). When a deer comes as i move to flip the safety i take my index finger and slightly turn the dial. I have a bushnell made by Eotech coming. It has a on off switch that remembers your settings plus it has 20 brightness settings.And water proof to i forget how deep.
