Cheek piece removel/how to?
I want to remove my cheek piece to modify it for a crankaroo is their trick to this I removed the allen screw and thought it would come right off but that is not the case.I am afraid I am going to break it if I am not careful it must slide or snap on.
Re: Cheek piece removel/how to?
Gerry it snaps in place,the screw is to make sure it stays there
http://autumnbreezebrittanys.com
- Doe Master
- Site Admin
Lay it flat on the table with the bottom facing you . With a sudden push down on the bottom of the cheekpiece and it will snap off .
