Right rubber stopper split, already??
Athena1
Post by Athena1 »
How long should it take the string stoppers to split? My right one is already split.
Re: Right rubber stopper split, already??
They'll split if your string is in contact with the stoppers, if you have the seam lined up with the string or if you dry-fire the bow. Otherwise I don't know. I think most of us have had a couple of hundred shots without splitting.
koko
Post by koko »
I bought a spare set of rubber stoppers right when I bought the whole S5 setup. You never know when one is going to split. I didn't want it to be during hunting and not have any on hand. But I hope they last longer than that. I still haven't shot the bow with the S5 on it yet. It's sitting on a hanger unstung in my shop.
2010 Equinox
Boo string with cat whiskers
camo munchmount
Big John GT III arrows
with 100 grain 3 blade meat seekers
Athena 1, something is wrong. You really have to contact a Excalibur warranty center. Meaning Danny Miller (USA) or Excalibur if your dealer isnt going to swap out that bow for ya and your running the correct brace height and all scope mounts and screws are TIGHT.
Your POI, safety mechanism, split rubbers are all indicators that something is amok. This isnt common. Thats my opinion.
bucknbill
Post by bucknbill »
i have a couple hundred shots on mine with no problems..the string is set about a string width away and the seams are never lined up with the string..rotate a little every once in a while...mine look like they,re ready for 300 more shots
S5 string stoppers
3x Proview
ComfyBear string
2219,s Blazer vanes, Muzzy 3 bld 125,s..they fly straight
John 3:16
Post by robertyb »
Mine are still looking good but the left side is almost touching the string and the right side is a string width away. I guess my tiller is off a little. I have checked the bolts and screws and everything is tight. It is still shooting quarters at 40 yards also. Should I back it off another twist?
awshucks
Post by awshucks »
can't have above and a tiller problem, imho.
Post by robertyb »
Just saying what my eyes are seeing.
It may be in the riser holes Dan. Your tiller can be out a fair bit and drive nails with field tips and get wild with a fixed broadhead. I had that happen with a Vortex and ended up sending putting on new limbs.
Post by robertyb »
I measured the tiller and it is off about 1/16" side to side.
Hoagy
Post by Hoagy »
I noticed a difference in string gap between the 2 rubber stoppers on my setup & thought the tiller may be off but after carefully measuring the tiller was correct. I discovered a 3/64" difference in the lengths of the rubber stoppers. Now that isn't much but it's noticeable when the brace height gets close to the stoppers.
I'm not worried about it as it seems to me the next set of rubber replacement stoppers will take care of this slight difference. :D
Just saying,
Hoagy
