Excalibur cheekpiece
fuel80guy
Post by fuel80guy »
Does anyone know if a excalibur cheekpiece fits on a Ibex?
I followed the instructions but the cheekpiece doesn't clip onto the stock and the screwhole doesn't line up as well.
georgiaboy
Re: Excalibur cheekpiece
Post by georgiaboy »
Yes it will fit...i cursed worse than a sailor before i snapped it on my ibex, but it will fit. I warmed mine up with a heat gun on low setting, have heard of some putting it in the oven long enough to get it warm. Getting it warm seems to help.
Good luck
Bulldog m380 blackout
Micro 355
Matrix 350LE
fuel80guy
Post by fuel80guy »
When I went to clip it on stock the screwhole was half an inch away from stockholders.So I looked at bottom of cheekpiece and the ribs were flush against stock.
I thought I was going to have to trim ribs down to make it fit.
houser52
Post by houser52 »
It should fit. I put one on mine and it was a little hard to snap on but it did.
I think theres a video that shows how to snap it on. I think its on the website but not sure where I saw it.
Ibex
NRA Life Member
NC Lifetime Sportsman
Bigger hammer!!!!
I "tapped" mine on with a rubber mallet and then "tapped" it a bit more until the screw hole lined up. I've heard of folks soaking it in hot water before installing it to help it pop on better. :)
maine hunter
Post by maine hunter »
:D they do go on hard, but when it's on......nice!!!!
rich l
Post by rich l »
I put mine on with a "C" clamp. It worked fine.
Bullzeye
Post by Bullzeye »
I messed around for a while trying to make it fit, then it just popped on easily, but I have no idea how I did it lol
S5 System
Shadowzone
Bullzeye
Post by Bullzeye »
S5 System
Shadowzone
