It appears that the new Matrix series Weaver style scope mounting rail has more equally spaced notches so that the scope rings can be moved to adjust the scope for each persons requirement. My 2012 Equinox does not have that capability.
Matrix Weaver style rail
- Deerstalker
Semper Fi
2012 Equinox
2012 Axiom SMF w/S5 (son # 2)
2012 Equinox
Re: Matrix Weaver style rail
The Guardian Anti-Dry Fire Scope Mount
I like also the fact that it also fits all other Excalibur models.
May have to get one for my 2012 Equinox as well.
Then switch over to the Flemish Dynaflight Crossbow String
With the speed increase combine with the reduced risk of dry fire tames my need for the Matrix for the time being .
http://www.excaliburcrossbow.com/catalog/crossbow/
the_guardian_anti-dry_fire_scope_mount
I suspect this about turn of an available anti dryfire device on an Excalibur Crossbow as standard on the Matrix 380 is it may not be as forgiving as other Excal models, only time will tell
