Arrow help
cecil30-30
Arrow help
Post by cecil30-30 »
I ordered 6 gold tip laser III's and low and behold the brass inserts and flat knocks wasn't installed..What a good glue to use??
Woodspike
Re: Arrow help
Post by Woodspike »
In my opinion it's hard to beat Hot-Melt... Strong hold, with quick removal and replacement.
secret
Re: Arrow help
Post by secret »
I use Steel Force Beyond Bond for inserts, i dont glue my nocks but that glue could be used also for nocks, vanes
wasp sst hammers
groundpounder
lumizone
ff string
UPSMAN
Re: Arrow help
Post by UPSMAN »
blue top gorilla glue for the brass inserts. I don't use aluminum nocks because I shoot lumenoks in all my bolts.
Muzzy Trocar-Bad to the Bone
strum
Re: Arrow help
Post by strum »
i use Tex-tite for carbons...its the blue color hot melt ..i like it because it is heat reversable..
Re: Arrow help
Regular "Gorilla" glue for wood,will put 'em in there and they will NEVER come out! Directions say to dampen one of two pcs. to be glued together. You can skip this if you wish, or use a q-tip to swab inside and make sure there are no dust particles left in there from your squareing proc.. This glue expands and could push insert out of shaft so I use masking tape as a clamp.Its great stuff. never loose one again kind of tough.
awshucks
Re: Arrow help
Post by awshucks »
Tried em all, X2 on the above post.....hot melt for nocks so I can change the dinged ones.......
Re: Arrow help
I use blue top Gorilla glue for inserts, nocks and fletching. :)
rattlerun
Re: Arrow help
Post by rattlerun »
Bohnings Ferr-L-Tite Cool Flex Hot Melt works great.
wheelie
Re: Arrow help
Post by wheelie »
Krazy Glue Gel for everything. Glue is expensive but I don't come cheap either. LOL Tried that blue top Gorilla Glue and it is the worst stuff I have ever used. Turns everything white. It is cheap and likely the reason.
Re: Arrow help
I don't think I've used anything more secure than 24 hr Easton HIT glue. Second to that would be any other 24 hr epoxy. Any epoxy reacts favorably with heat on removal, much better than instant glues.
