Can someone please square me away on bolts.
learn2flyfish
Post by learn2flyfish »
Okay,
I've found two Ibex bows, one aluminum barreled and the the other is a new SMF.
The information says use 350 weight arrows. I'm unclear if that is a total weight with broadhead/field point or just the shaft weight. Any clarification would help.
Thanks,
There are 10 types of people in the world, those that understand binary and those that don't.
JRS
Re: Can someone please square me away on bolts.
Post by JRS »
It is total arrow weight.
awshucks
Post by awshucks »
Get some BEE's w/: 2" Blazers 92 or 110 gr inserts, good as it gets..........Southshore does a fine job w/ quick service, btw. And 'a lot of helical' [from Jerry, owner] ain't that much.
The total minimum arrow weight is 350 grains, so stay above 350 gr. and your good.
Tekhanto
Post by Tekhanto »
What is the weight of a Firebolt arrow that comes with the Axiom ?
Say that comes with a field tip ?
Axiom (ole' Reliable)
Shadow zone
Sniper Hog Light
S-5 with dB Killer Bumpers
dB Noise Killers
Manta case
enormous wrote:The total minimum arrow weight is 350 grains, so stay above 350 gr. and your good.
Thats with points.If you go below that, you risk damage to your bow. If you go over that you slow down a bit. Slower is not a bad thing . The heavier arrows have a bit more penetration, and the noise from your bow will be down a bit.You just dont want to get too slow . Its a compromise. Most of the arrows I shoot are between 375 gr.and 430gr. They all work well. Have fun playing with it and find your "perfect" combo.
rbcss
Post by rbcss »
I bought some Easton xx75 magnums 20" 2219. it says on the web sight arrow is 13.8 grains with 100 grain field tip the total arrow was 470 grains. I thought that would be a very heavy arrow. but I like Easton so I gave it a try. these things flew straight flat and very accurate and had very good penetration. I was impressed.
I used the same arrow on my buck i shot this year and had a pass thru with it.Its in my avatar 2219 easton magnum.
