Bolt retainer
childrs
Bolt retainer
Post by childrs »
I added an anti dry fire mount to my Exocet. The bolt retainer extends quite a bit farther on the barrel now. Is there a shorter bolt retainer available or do I cut the original off and bend to match it to the same spot it was before?
Dash
Re: Bolt retainer
Post by Dash »
It's works fine where it is further down.
Is there any reason you want to shorten it?
childrs
Re: Bolt retainer
Post by childrs »
The longer bolt retention bar has a loud twang when shot. It is plenty accurate, just noisier.
lvt01
Re: Bolt retainer
Post by lvt01 »
Just use a piece of shrink tube on it. Takes a lot of the twang out of it.
Dash
Re: Bolt retainer
Post by Dash »
Shrink wrap helps, but I have a modified cable jax (bowjax) pulled over mine. The 2 lower rubber fingers are cut off so not to interfere with the arrow. That bowjaxtype jelly rubber is a great sound deadener. What distance is there between your arrow tensioner and rail without an arrow inserted?
One of my bows arrived here without a gap and was noisy as hell, so I just bent the retainer back carefully to the same as the other bows (about 2-3mm from rail), then checked the tension. It must be tight enough that the arrow must not fall out when the bows pointed downwards.
Rufus
Re: Bolt retainer
Post by Rufus »
I cut mine shorter but beware it is really hard to drill a new hole in it
