So whats with the new strings ?
BrotherRon
Post by BrotherRon »
I hear that Excalibur has decided to shorten their strings a bit.
What influence will this have?
Just curious
Ron.
Jeremiah 29:13 :thumbup:
Re: So whats with the new strings ?
Allow them to settle without ruining the bumpers in shipping. Hopefully be high enough on brace height when sighting the bow in as well.
ComfyBear
Post by ComfyBear »
Dan is correct. It was found that in-between assembly and delivery of the Matrix crossbows, the strings were creeping more than expected. By shortening the initial overall length the desired brace height should be obtained by the time they are sold.
ComfyBear
ComfyBear Strings
To thine own self be true.
Remove thine mask Polonius.
strum
Post by strum »
where did you get this info?..just curious
BrotherRon
strum wrote:where did you get this info?..just curious
Dan Miller mentioned it to me when I talked to him yesterday.
I got the scoop from Brother Ron! Thanks, now hopefully a stringing tool in the package will be considered!
The limb dimensions were shorted very slightly which caused the issue with string length and brace height. The strings were shortened by a mere 3/16" which accommodates both old and newer dimensions.
