Locktite
michaelrbauer
Locktite
Post by michaelrbauer »
When assembling a crossbow should I use loctite blue or purple?
Vortex, Lumiscope, 100 gr spitfires
43.11 N 88.22 W
Re: Locktite
Post by robertyb »
I like Blue. Holds well and releases easily when needed.
Re: Locktite
Blue 242, let set up over night minimum.
Re: Locktite
I use green (post assembly) on all the limb fasteners. For the most part, that is the only place I put loctite. Most people do not put enough beef into fasteners which is why you hear they come loose with or without loctite. If you put enough torque into a steel fastener that goes into aluminum, the metal under the fastener head will gall and lock the fastener in.
That been said, use any medium loctite anywhere on your bow. Use as little as you think you can get away with. For example, a whole drop of loctite in scope mount screws is too much.
Re: Locktite
Post by paulaboutform »
Hi Michael, and welcome. I've seen the colors of loktite vary so make sure you get the medium or low strength. I use the blue medium strength loktite.
Re: Locktite
Boo nailed it, lot of folks use too much, and that just makes it much longer to set up. I put the drop on a piece of cardboard, or something, and touch the bolt to it, if you feel it is too much, dab it with a paper towel.
Less is more sometimes!
bubba
Re: Locktite
Post by bubba »
Now this is what the forum is all about!!!! Thanks guys I sure would have used more love it....
strum
Re: Locktite
Post by strum »
Mr Big Meat Boo puts a lot of Beef Into it :lol: :lol: :lol: :lol:
Oh and yes on the ..watch the colors thing ..I have some blue that the label says "high strength" I think its a Permatex brand
Bullzeye
Re: Locktite
Post by Bullzeye »
Just remember that there is a big difference between dried Loctite and cured loctite, I always let it sit over night. As already stated very little is needed, just a tiny drop on the tip is all it takes, no need to apply it the whole length of the threads, by applying it on the tip, when you screw it in it will get evenly spread over all the threads. You also want to make sure the bolts/screws are free of any grease or oil before applying the Loctite.
S5 System
Shadowzone
MprBlackout
Re: Locktite
Post by MprBlackout »
Does anyone know the proper torque specs for any of the fasteners?
Manufacturing requires certain specs, so should reassembly. Knowing these numbers would help. While working with race and street engines, we use inch and ft # wrenches for every fastener.
Thx, MPR Blackout
380 BLACKOUT w/ T-zone 100
Tact handle, ACP trigger, Dr Stirrup w/ bumpers
335 Micro BLACKOUT & 355 Micro camo, both ACP triggers, T-zone 100'd, all w Lumi'd weight matched Zombies
