DRY firing!
DRY firing!
What is everyone opinion on dry firing? Do you guys/gals think Excalibur bows can handle the odd one or two dry fires? Thanks for the help guys!
Re: DRY firing!
...Hi Nathan...welcome to the forum...you really do not provide a lot of information for us to help you...what kind of bow are you shooting, with ADF or without, partial or complete dryfire...have you already DF's your "?" ?...did it have an arrow in and not just pushed back enough, or no arrow...Nathan_armstrong wrote:What is everyone opinion on dry firing? Do you guys/gals think Excalibur bows can handle the odd one or two dry fires? Thanks for the help guys!
....as you can see these are just some of the variables...help us help you!...others will most likely chime in...
...also, why not complete your registration entering where "you be from"...it helps us to help you better...that is, if you plan on sticking around the camp fire and being part of the sing-a-long!
Anthony
Anthony
Anthony
- BrotherRon
Re: DRY firing!
As stated... more info is needed.
Which model & size.
Factory or custom string?
Ron.
Which model & size.
Ron.
Jeremiah 29:13
Jeremiah 29:13
Re: DRY firing!
Well I can speak from experience that a vortex and a M355 can take a few dry fires.
My 355 was no worse off then the vortex other then the bent recoil plates. I just removed and hammered them flat.
Re: DRY firing!
My older brown Vixen gets used for clinics to introduce new shooters, and many 3D tournaments - its been dryfired often. It held up amazingly well until one day when it just had one dryfire too many. New limbs on it and its business as usual. Love my xbow!
Re: DRY firing!
VixChix wrote:My older brown Vixen gets used for clinics to introduce new shooters, and many 3D tournaments - its been dryfired often. It held up amazingly well until one day when it just had one dryfire too many. New limbs on it and its business as usual. Love my xbow!
....and you look way cool when you are in shooting stance also Moni....
Anthony
Anthony
Anthony
Re: DRY firing!
The older models wid Dacron flemish strings did very well of survivin dry fires. Even the newer mag tips faired well. I can't say on the Matrix or Micro's as i haven't dryfired either of them
- one shot scott
Re: DRY firing!
It should be avoided at all costs. The exo series can withstand it more so than the matrix line. ADF is good life insurance for the matrix, as well as string stops.
would I buy a bow that's been dryfired? yes, if it were an Excalibur.
Re: DRY firing!
the deal is no dryfire is good. I have seen excaliburs take multiple dryfires with no damage and ive seen em damaged on the first one. the cool thing is, damage or not you wont be out of commission long. They are easy to fix yourself or if you choose to send it in for replacement limbs then that doesn't take long either.
And now with the anti-dryfire mech its almost a non issue.
Re: DRY firing!
Hi, and thank you Anthony. I'm shooting a new grizzly, it doesn't have the ADF and no I have not DF mine but one of my friends have the exact same set up and did fully dry fire his. Just thought I'd be a good friend and ask you guys here! You guys really seem you know your stuff!! And I'll finish it now
Re: DRY firing!
Dry fired my exocet 175 and my 355 with no problems
The 335 Micro to, but it has the ADF!!
Re: DRY firing!
I think the Grizzly will be fine, but I would try really hard to avoid any dry firing going forward.
Re: DRY firing!
....Nathan, as with any DF or partial DF one must completely look over the limbs and string and assess as to whether the limbs has sustained any tell tale signs of damage...If there is none that "carry on"....however your friend must seriously consider the ADF....
Anthony
Anthony
Anthony
Anthony
Re: DRY firing!
amythntr wrote:....Nathan, as with any DF or partial DF one must completely look over the limbs and string and assess as to whether the limbs has sustained any tell tale signs of damage...If there is none that "carry on"....however your friend must seriously consider the ADF....
Anthony
Okay thank you Anthony and everyone else
- pembertont
Re: DRY firing!
Hello...new to the forum, but I've witnessed an Equinox and an Axiom dry fired. One threw the string and one didn't. Both survived unscathed and the scopes both worked fine afterward too. Excals can definitely take it better than any other xbow out there! Best hunting purchase I've made!
Tom
Tom
Excalibur Equinox
Shadow-Zone Scope
Flemish Fast Flight String
Zombie Slayer Bolts
Slick Trick 175's
Shadow-Zone Scope
Zombie Slayer Bolts
Slick Trick 175's
