Addendum needed for warranty issue.
I've about had it with my 380, every time I put the cross hairs on the same spot my bolts keep breaking. Who knew if you simply look at the same spot with an excal the bolt will just keep hitting the same spot. It's almost as if it's reading my mind
Mad max 380
Stock string
Dr stirrup kit
Zombie slayers
Rage Hypodermic 100 gr
Leupold Crossbones
Stock string
Dr stirrup kit
Zombie slayers
Leupold Crossbones
- Carnivorous
Re: Addendum needed for warranty issue.
LOLBcwn wrote:I've about had it with my 380, every time I put the cross hairs on the same spot my bolts keep breaking. Who knew if you simply look at the same spot with an excal the bolt will just keep hitting the same spot. It's almost as if it's reading my mind
Keep at it you will Robin hood an arrow sooner or later....
