serving
serving
my serving started to fray a little last fall so i bought a new string. I kept the old one for an emergency and today while turkey hunting the serving on the new string unraveled. I put the old one back on and it will be fine for awhile.
my question is .... can the string just be reserved? what kind of serving? I have a buddy who works on vert compounds and can do those. he told me to find out what type of serving was recommended for these strings.
micro 335
micro 335
Re: serving
Angel Majesty in .036" diameter. You have to get it tight, which is the same for the verticals, but smaller diameter serving is used for that application. Yes, your strings can be reserved. I would recommend polishing the trigger latches, and also check the brace height line for sharp edges, something is chewing up your serving it sounds like.
Re: serving
0.036" Angel Majestybobcat wrote:my serving started to fray a little last fall so i bought a new string. I kept the old one for an emergency and today while turkey hunting the serving on the new string unraveled. I put the old one back on and it will be fine for awhile.
micro 335
Re: serving
Check the nocks on your arrows. I had an arrow where it had a crease in it from being touched by another shot. It felt smooth, but under a magnifying lenses there was a fine edge that was nicking the serving.
Parker Challenger
Gen-1 Micro 335 Camo
Matrix Cub
Bear Legion Compound
Matrix Cub
Re: serving
thanks for the replies. i will check my arrows. how do you polish the latches? steel wool?
Re: serving
where would i find the .036 serving? lancaster archery discontinued it.
Re: serving
Danny Miller sells it .bobcat wrote:where would i find the .036 serving? lancaster archery discontinued it.
8ptbuk's Flemish Strings
8ptcustomstrings@gmail.com
Re: serving
Send me yer string/s i will serve them cost is postage
- bitemybait
Re: serving
I find BCY Powergrip Serving @ .025 works great the smaller diameter = more
serving less separation
Re: serving
vixenmaster wrote:Send me yer string/s i will serve them cost is postage
sweet! thanks. soon as turkey season is over i will send both ! sent you a pm for address. very generous.
Re: serving
They will have A Majesty .036 servin on them when returned. Yes sir i need the practicebobcat wrote:vixenmaster wrote:Send me yer string/s i will serve them cost is postage
Re: serving
Mike, you are a good man.vixenmaster wrote:They will have A Majesty .036 servin on them when returned. Yes sir i need the practicebobcat wrote:vixenmaster wrote:Send me yer string/s i will serve them cost is postage
Re: serving
Very nice of you ..But your strings you sold me are so good it will be longtime I think ...vixenmaster wrote:They will have A Majesty .036 servin on them when returned. Yes sir i need the practicebobcat wrote:vixenmaster wrote:Send me yer string/s i will serve them cost is postage
- nchunterkw
Re: serving
The last time I tested this it broke 25 shots in on a Vortex. AM 036 is the way to go.bitemybait wrote:I find BCY Powergrip Serving @ .025 works great the smaller diameter = more
trinitystrings412@gmail.com
Re: serving
X2 !nchunterkw wrote:The last time I tested this it broke 25 shots in on a Vortex. AM 036 is the way to go.bitemybait wrote:I find BCY Powergrip Serving @ .025 works great the smaller diameter = more
