Decocking micro 335
Decocking micro 335
Ive cocked and shot it but have not tried decoking. Just leary since your holding 270 lbs with 1 hand
MIcro 335 GEN 2
Widow Maker/ Undertaker
Nchunterkw Strings
Vixenmaster Slave Stringer
Cabelas Laser Stricker 11 Broadheads
Nchunterkw Strings
Re: Decocking micro 335
No trouble or worries needed at all, just remember to depress the anti dry fire lever above the safety, I use my thumb for this.
X2 No big deal at all.Normous wrote:No trouble or worries needed at all, just remember to depress the anti dry fire lever above the safety, I use my thumb for this.
If you don't have any problems cocking it, you won't have any issues decocking it. That one hand will still be holding the same amount of weight... just as if you were using both hands (one on each handle).
~E
~E
- BrotherRon
Just don't hurt yourself trying to pinch your cheeks together.
Jeremiah 29:13
Jeremiah 29:13
Remember to remove your arrow!
Although it sounds like it might be hard to do, I find it takes way less strength to decock it than it does to cock it. My only recommendation is to make sure you pull up firmly before releasing the string. This is only to confirm that you have the hooks fully engaged on the string.
Recovering Excalaholic
DuckHunt wrote:Although it sounds like it might be hard to do, I find it takes way less strength to decock it than it does to cock it. My only recommendation is to make sure you pull up firmly before releasing the string. This is only to confirm that you have the hooks fully engaged on the string.
X2
2010 equinox,
known as doe bow
vixenmaster custom string
xx75 Easton 2219,s
firebolt arrows
S5 pads
be safe in all you do
see ya in the woods
known as doe bow
xx75 Easton 2219,s
firebolt arrows
S5 pads
see ya in the woods
It is ONLY 220 lbs.
and it is a lot easier than cocking the bow in the first place.
- Carnivorous
The same procedure is the key.
Remove arrow.
Attach hooks as if cocking the bow.
Pull one handle like you mean it and hold
Safety off
Depress adf and hold
Check for no arrow
Check again for no arrow
One more time ensure no arrow
Pull trigger and let it down nice and easy
Easy peasy...
Remove arrow.
Safety off
Check for no arrow
Easy peasy...
Like some of the other guys are saying. I have had no problems at all and as long as you keep your string tight and make sure you push down on the anti fire you will be fine.
Excal Vortex
Excal Micro 335
NAP Spitfire Max 125 grain
Hawke XB Pro 30 SR
Excal Micro 335
Hawke XB Pro 30 SR
Same method you use when decocking after you adjust your brace height
easy peasey
easy peasey
335 Micro "THOR" as in "Thorin Oakenshield"
RamCat 125gr. AKA Battle Axe
NChunterKW Flemish String
15.5" Excalibur Dan Zombies
When it Flies something dies !
Thanks to all that replied.
I did it and it didn't hurt a bit.
Good luck to all and hope you dont have to savor the flavor of tag soup.
MIcro 335 GEN 2
Nchunterkw Strings
Nchunterkw Strings
