scope rings
ihavethetools
scope rings
Post by ihavethetools »
Handling the stock scope rings that came with my 350LE doesn't have me feeling good about them. Any advice on which rings to upgrade with ? Thanks all.
350 SE, Boo Custom String, Munch Alum Rope Cocker Hooks
Quake Sling, Hawke SB1 SR
Vixenmaster String,18" Zombie Slayers, Firenocks
DrStirrup dBKiller Limb Silencers & string bumpers.
Re: scope rings
Leupold rifleman rings. They are nice rings, and wont break the bank. I know the feeling about the factory rings.
Re: scope rings
X2 on the Rifleman rings.
WVCBH
Re: scope rings
Post by WVCBH »
I really like the Weaver Quad Lock rings :-)
Still lovin' my EXCALIBUR MICRO 355! :-)
Deaf jeff
Re: scope rings
Post by Deaf jeff »
my vote goes to the Burris zee rings, all steel with torx type screws.
steel screws into aluminum threads are not a good combination....just my opinion
IN GOD WE TRUST
Jeff
animals are killed, crops are harvested
matrix 330
100gr spitfire maxx
Boo strings
excaliber strings
Dagriz knife
nyexhunter
Re: scope rings
Post by nyexhunter »
I have an XB30 scope and am very happy with the Vortex Viper scope rings, the 30mm low; part # VPR - 30L.
I prefer the lowest scope mount position I can get on all my rifles as well as my Xbow. That way I can keep my head tight to the stock when shooting; never been a fan of cheek pieces to elevate head in line with scope.
Re: scope rings
Image[/URL] Weaver six bolt (torx) medium one inch tactical rings no move ....ever .overkill maby . No move ever... worth 40 bucks for sure.
rein1
Re: scope rings
Post by rein1 »
Deaf jeff wrote:my vote goes to the Burris zee rings, all steel with torx type screws.
X2 ,, Steel screws and aluminum threads aren't a reliable combo
ThackMan
Re: scope rings
Post by ThackMan »
The Weaver 1" Lever-Lok quick release rings I originally bought for my muzzle loader are worlds better than the aluminum Excalibur rings. (Torx screws for one) And only $36.45 USD.
BD400 w/ TT, HHA, Leupold 2-7x 33mm, 8ptbuk String, Munch Mount "Y", Kwikee-3SS, Dr Stirrup Kit
Grizzly, 8ptbuk String
18" SSST 112 gr Insert, SK300, Ignitor
18" BEZS 110 gr insert, Blazers, Lumenok
VPA 3 blade vented 100 gr
racking up points
Re: scope rings
Post by racking up points »
Use Leupold Rifleman rings with confidence. The idea that a steel fastener is somehow detrimental to an aluminum ring is a non factor here because you're not torquing the screw down enough to strip the tapped hole and I haven't seen galvanic bonding.
Keep in mind guys, we are shooting crossbows here, not .300 WIN mags. I have never had an issue ever and they are about 1/2 the weight of a steel ring. If using something twice as heavy appeals to you, I suggest topping it off your bow with a Hawke scope :lol:
Last edited by racking up points on Thu Jan 05, 2017 6:43 am, edited 2 times in total.
racking up points
Re: scope rings
What fastens your limbs to your riser and your riser to the rail?
Deaf jeff
Re: scope rings
Post by Deaf jeff »
just curious here...could this aluminum threads and steel screws have anything to do with all the comments about crossbow screws loosening up?
when i have a choice i will use what gives me the most confidence. to each his own
IN GOD WE TRUST
Jeff
matrix 330
100gr spitfire maxx
Boo strings
excaliber strings
Dagriz knife
foofoo
Re: scope rings
Post by foofoo »
Leupold PRW-S never let me down. pick up a wheeler torque wrench and youll never have issues stripping threads.with scope rings steel screws into aluminum only need like 12-15 inch pounds. steel to steel 17-25inch pounds depending on ring brand and suggested manufacturer specs.not a big fan of loctite. rather run the screws though once to clean up the treads and use a drop of oil or string wax. that will help you get proper torque. coating the screw helps with slowing the galvanic process.
ihavethetools
Re: scope rings
I'll be putting a Hawke XB 1 on my bow. I have a Munch Mount on it. Would I be OK with medium mounts or should I go with low mounts ? Just worried the low ones will not have enough clearance.
Re: scope rings
Post by paulaboutform »
I have a number of different rings on different bows. I'm very impressed with both the Burris Signature Zee Rings and the Vortex Rings. I also quite like my Monstrum Tactical Cantilevered Rings with the picatinny top for attaching my laser sight which works very well.
