Slick Tricks
ThunderXB
Slick Tricks
Post by ThunderXB »
OK, while I love my 100 gr Spitfire mechanicals (1 1/2" - 2" versions) I will be testing Toxics and Slick Tricks for fixed blade alternative.
MY QUESTION is this:
Which Slick Tricks seem to the best/most appropriate.
They do have a specific 1 1/8" Crossbow version and that would be my normal choice, but they have a large variety and other styles look good too.
Anyone have any good/bad experience with them??
Re: Slick Tricks
Slick Tip,
To improve runout when using Slick Tricks position the rounded side of the supplied washer toward the tip or point.
You may need glasses :lol:
Re: Slick Tricks
Post by paulaboutform »
Rich, regarding the slicks, they're all very well made, razor sharp, and fly great. I've shot the 100gr standards and 125gr grizztrick 2's. Just make sure to spin test them to make sure you have no wobble. If you do simply loosen them and turn the washer then tighten and test again.
Regarding the toxics, they're just awesome. I have found the 100gr to be more accurate which makes sense simply because of the smaller profile. However, don't let the smaller profile fool you. They still leave a blood trail like you won't believe.
ThunderXB
Re: Slick Tricks
Post by ThunderXB »
paulaboutform wrote:Rich, regarding the slicks, they're all very well made, razor sharp, and fly great. I've shot the 100gr standards and 125gr grizztrick 2's. Just make sure to spin test them to make sure you have no wobble. If you do simply loosen them and turn the washer then tighten and test again.
I'll get that 18-1 and hold it for you if I can practice on it with the Toxics in the meantime?? :shock:
Re: Slick Tricks
Shipping that 18-1 will be lots cheaper after you practice on it a while with those Toxics!
bowman81
Re: Slick Tricks
Post by bowman81 »
I use 125 gr. Standards (1") and Magnums (1 1/8") out of a Matrix 355 and an Axiom. They fly great and both are deadly on game. I chose that weight to give me a 400 gr. overall arrow weight.
racking up points
Re: Slick Tricks
Post by racking up points »
I have the 175gn Slicks and I also use the 170gn NAP FOC on the same arrow. I have yet to use the slicks on game but like Paul said if they wobble just loosen and reset the washer until they spin true. They fly just like the FOC out to 40y and possibly further - I just haven't played with them much past that distance. Can't wait to see the results on deer or bear this fall.
SEW
Re: Slick Tricks
Post by SEW »
For 3 seasons, I've had the same arrows tipped with either 175g Xbow Tricks or FOCs. Xbow a Tricks indexed 3,6,9,12, FOCs 6,12. Same poi except by 100 yds, the Xbow Trick is 1" low.
I'm now using Griz Tricks 125g/92g inserts on STs and on another combination 26g inserts/175g Xbow Tricks and FOCs.
nchunterkw
Re: Slick Tricks
Post by nchunterkw »
I've shot the 100gr standards, 125gr Magnums ad 150gr Xbow Tricks. All fly well out to 40. As was said before spin test them and adjust washer as required. I've also found you can "mix and match" blades in any ferrule with no loss of accuracy. All leave a big hole so don't worry about that. Even the "tiny" 1" standard makes a big hole.
[email protected]
