Broadhead targets
Broadhead targets
I'm shooting a 350 and am looking for a good broadhead target, something that will stop my bolt cutters but won't cause me to dislocated my shoulder trying to remove them,the target will be used to sight in my broadheads and 3or 4 shots before I go hunting, that's it. All the other shooting will be with field points into a big shot 450 which is an excellent target
Re: Broadhead targets
Any of the Rhinehart Targets are excellent. The 18 in 1 is probably the best bang for your buck but I actually prefer the rhinoblock for the extra size. They're the exact same material but they're shaped differently with the rhinoblock having a little more surface area.
I use 18-1
X2 and spring for a pair of Danny Miller arrow pulling pliers. Make life easy!paulaboutform wrote: ↑Thu Sep 07, 2017 12:31 pmAny of the Rhinehart Targets are excellent. The 18 in 1 is probably the best bang for your buck but I actually prefer the rhinoblock for the extra size. They're the exact same material but they're shaped differently with the rhinoblock having a little more surface area.
I'm using the cabelas brown one with green spots. Made by rhino I think maybe?
Once you learn the trick the arrows slide out pretty easy. Stops my micro and my 355 matrix from 15 yards no problem
- Deerstalker
18-1, although that BEE has a field point. Remember to pull the arrow straight out when using a BH.
Semper Fi
2012 Equinox
2012 Axiom SMF w/S5 (son # 2)
2012 Equinox
If you remove the logo off your arrows with acetone, you'll have a much easier time removing them. With that said I'm a 18/1 fan myself.
Hank
Hank
Can I get an Amen? The painted logos will "Weld" themselves to a broadhead target. You will be very happy that you did this. Also a tiny bit of arrow lube such as scorpion venom will make them come out easier too.hankenhunter wrote: ↑Thu Sep 07, 2017 11:51 pmIf you remove the logo off your arrows with acetone, you'll have a much easier time removing them. With that said I'm a 18/1 fan myself.
Hank
- SummitSitter
What Danny Miller's contact info?flightattendant100 wrote: ↑Thu Sep 07, 2017 4:06 pmX2 and spring for a pair of Danny Miller arrow pulling pliers. Make life easy!paulaboutform wrote: ↑Thu Sep 07, 2017 12:31 pmAny of the Rhinehart Targets are excellent. The 18 in 1 is probably the best bang for your buck but I actually prefer the rhinoblock for the extra size. They're the exact same material but they're shaped differently with the rhinoblock having a little more surface area.
Rinehart when using broadheads for me.
http://www.ebay.com/itm/NEW-Rinehart-Targets-X-Bow-2-Go-Self-Healing-Crossbow-Archery-Target-18911/311558476806?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Matrix Cub
Montec CS 100 grain
Montec CS 100 grain
SummitSitter wrote: ↑Fri Sep 08, 2017 9:50 amWhat Danny Miller's contact info?flightattendant100 wrote: ↑Thu Sep 07, 2017 4:06 pmX2 and spring for a pair of Danny Miller arrow pulling pliers. Make life easy!paulaboutform wrote: ↑Thu Sep 07, 2017 12:31 pmAny of the Rhinehart Targets are excellent. The 18 in 1 is probably the best bang for your buck but I actually prefer the rhinoblock for the extra size. They're the exact same material but they're shaped differently with the rhinoblock having a little more surface area.
Horizontal Archery
37432 5th Avenue
Sardis, OH 43946
Phone: (740) 483-2312
Matrix Cub
Montec CS 100 grain
Montec CS 100 grain
If you Google Horizontal Archery in Sardis, Ohio you should get Danny's number....even though he doesn't have a website. His plier pullers are a MUST have in my opinion. I keep a pair in my shop, another with my gear, another in my truck....and a spare just in case. You'll love them for making arrow pulling a breeze.
- SummitSitter
I just spoke with Danny and he is getting a set of arrow pullers right out to me. Very nice guy!
- SummitSitter
I'm planning on doing this with my Zombie Slayers. Do the graphics come off easily with acetone and a rag, or do you need an adhesive pad to scrub the graphics off?hankenhunter wrote: ↑Thu Sep 07, 2017 11:51 pmIf you remove the logo off your arrows with acetone, you'll have a much easier time removing them. With that said I'm a 18/1 fan myself.
Hank
I just use a rag. They come off easy.SummitSitter wrote: ↑Mon Sep 11, 2017 8:05 pmI'm planning on doing this with my Zombie Slayers. Do the graphics come off easily with acetone and a rag, or do you need an adhesive pad to scrub the graphics off?hankenhunter wrote: ↑Thu Sep 07, 2017 11:51 pmIf you remove the logo off your arrows with acetone, you'll have a much easier time removing them. With that said I'm a 18/1 fan myself.
Hank
Hank
