The new Excalibur crank
https://youtu.be/2oSgLk6Hog0
If the link doesn't work, search for Excalibur Charger in Utube.
bigbowman
Re: The new Excalibur crank
Post by bigbowman »
I’m sure it would be necessary for anything over 200lb pull! If I ever decide to buy a power eater like that then it would be a must, but until then my rope cocker works just fine. 😉
hunter with MS
Post by hunter with MS »
It looks like it can be cranked from either the left or the right side or am I seeing things on the video .
newbie
Post by newbie »
Yes either side. It's a nice crank easy to use and much safer then the old ones. Awesome upgrade.
It will work on any Micro.
Matrix if it had the cutout and two top holes like the micro.
I like the retractable rope feature that it seems to have but one thing I would like to know is will it bust your knuckles if you let go while cocking or is there an auto brake feature?
Billy
bigbowman
Post by bigbowman »
I believe he said it comes with a retro fit if your stock doesn’t have the 2 holes? I thought he mentioned it.
ko4nrbs
Post by ko4nrbs »
It appears Excalibur has delivered with this Crank!! Glad they responded to all the requests for a new Crank.
Bill
Excalibur Firebolt Arrows
NuFletch Ignitor Nocks
hunter with MS
Just trying to figure out how to retro fit it to my Matrix 330 with solid stock . Any Ideas ?
newbie
Post by newbie »
Bcxbow wrote:
Wed Jan 10, 2018 6:42 pm
Billy
No it brakes as soon as you stop cranking. knuckles are safe. It has a wrist strap so you can uncock safely and it won't run away on you.
newbie wrote:
Wed Jan 10, 2018 7:57 pm
Billy
That’s good, i’ll probably get on the list if we get good reports from this weekend. David at Wyvern’s said it may be 1-2 months before he has them in stock.
Thanks for the info
Billy
newbie
Post by newbie »
it says not to decock but you can same as the old c2. It just free wheels so be careful.
newbie
Post by newbie »
bobcattrapper
Post by bobcattrapper »
How will this fit my matrix 330 with a cheek piece?
hunter with MS
It showed in the video decocking with the crank but in the photos it states on the mounting hardware . Warning DO NOT DECOCK WITH CRANK ! What gives >
Post by robertyb »
hunter with MS wrote:
Wed Jan 10, 2018 7:14 pm
It looks to me like you can simply measure and drill the holes in your stock. Why should it matter that it is not cut out like the micro stocks as long as the holes are there?
