Black eagle/dragon claw
Are the arrows in the title the same? Looking at wyvern for 6 -12 arrows with lumenok. Also, are the zombie slayers better/worse. Thanks for the input.
Micro 335 nightmare, Axiom
Swhacker 150 grain, zombie slayers
Wants: micro ultra lite, adj. stock, take down, good trigger, good scope , low 300 speed to keep "cockable" w/out crank
Re: Black eagle/dragon claw
I believe the Dragon Claw is the same carbon as the Black Eagle Executioners. They should work fine out of your Micro 335.
The Black Eagle Zombie Slayers are a bit stiffer. I use them (or Spynal Tapps) in all my Micros. I'm sure others with more experience with Executioners or Dragon Claws will weight in.
Recovering Excalaholic
I'm also open to other arrow suggestions and makers/sellers
- AJ01
I get mine from Wyvern's. Dave will fix you up!! I shoot a Micro 355. Black Eagles. Killed 4 deer last season. Works for me.
- nchunterkw
I use only Zombie Slayers in all my crossbows. Corssbows are not like vert bows in that you need a certain spine to clear the riser. So the stiffer the better. They stabilize quickly and penetrate better. Zombies are about the stiffest I have seen. Gold Tip Nitro Pros are pretty good as well but I find Black Eagle to be a bit better on quality control. Have used Easton FMJs but the Al component of them can still bend...so I have moved on from them.....even though I like the 14GPI weight. I wish BE made a high GPI arrow
trinitystrings412@gmail.com
Thanks everyone. I found some older threads on this topic that were very helpful as well. I just placed an order with Wyvern for the zombie slayers.
