Newest project
BrotherRon
Newest project
Post by BrotherRon »
We don't have running water at our cabin and have been getting water from an artesian well about 7 miles away.
I just ordered everything needed to put in a sand point well and will be installing it as soon as Menards gets the pump in. (6/20/21)
We have a spring fed pond there but my cabin sits on a hill about 15 feet above the pond. Wondering if I would be safe trying to put the well next to the cabin, or if I should go down the hill a ways? They recommend not going any deeper than 23 feet with the hand pump I ordered.
It's just a small one about 14"tall -- The bigger one runs around 300.00 - 500.00 and the whole set-up I purchased is only 300.00 pump included.
I will be using a hand pump if possible... I do have an electric pump and could run it with the generator but would rather use the hand pump.
Jeremiah 29:13 :thumbup:
Re: Newest project
When I built my house, I had 2 people witch for the best place for a deep well. I also talked to a couple of others that witched for water. All said the same thing, that water runs in veins. So if it were me, I'd have a couple of people who witch for water to tell you where to place your point.
Re: Newest project
Fri Jun 11, 2021 5:26 pm
We had a maintenance map of the water lines in a building that was over a hundred years old, they drilled eight times and missed, the sticks found it the first time.🙃
Re: Newest project
xcaliber wrote:
Fri Jun 11, 2021 6:46 pm
Do you ever wonder how that works? Grass skirts and hoola dancers if you ask me! I bet my wife who has said “I just know” understands!
frisky
Re: Newest project
Post by frisky »
Hope you have help poping in that point. Some times easy and other not so easy. Keep the pipe connections tight, check them often! Rocks and hard pan will slow you down.Enjoy!
2007 Phoenix
Custom Wood Stock
Gold Tip II 311 Grain
Boo Astroflight String
Varizone Sighting
grouse
Re: Newest project
Post by grouse »
Groundwater exists under huge portions of the earth's surface. It is usually in large pools and seldom in "veins". Springs, seepage, swamps, and successfully drilled wells in the area are all signs that there is ground water in an area. There are no "magic sticks" or people with a sixth sense that can locate water in anything other than a random fashion. Trained hydrologists can help select more likely places to drill without the help of forked sticks.
elkaholic
Re: Newest project
Post by elkaholic »
Don't ask me why or how but I've seen a boss drive up and use bent copper rods stuck in plastic Dixie cups and find waterlines , power lines and even gas lines. Etc.
Re: Newest project
I looked at the government records for local well depth and ours was the typical depth. We live 2 miles north of Lake Ontario and at the bottom of Oak Ridges Moraine which is a huge aquifer. All that means that I'm just about guaranteed water but how much and where to drill. Neither of the water witchers want no money but when they were done, I made them take $50. I figured i had nothing to lose and everything gain.
One of them is an excavator. He regularly uses divining rods to water, gas and power lines.
I am a staunch believer in science, no grass skirts and hoola dancers for me but......
Re: Newest project
There are many things in this life that I don’t understand and probably never will but after seeing someone find water under a foot of concrete a hundred years old, I will keep that on my list of things beyond my learning and understanding.
Re: Newest project
Sun Jun 13, 2021 8:27 am
Awww, I kinda like the hula dancers.😎
Re: Newest project
flightattendant100 wrote:
Mon Jun 14, 2021 5:45 am
Me too! 8) What were you talking about again? :lol: :lol: :lol:
