Gold Tip Bolts
scratcherky
Gold Tip Bolts
Post by scratcherky »
I have been using Gold Tip Lazer II 20 inch bolts in my Phoenix crossbow. They have been discontinued and I would like to continue using Gold Tip bolts. Can anyone advise which current Gold Tip bolts would be equivalent to the Lazer II bolts?
Man and man's best friend still looking at the green side of sod.
nannyhammer
Re: Gold Tip Bolts
Post by nannyhammer »
Think they are the Swift line.
wheelsquad
Re: Gold Tip Bolts
Post by wheelsquad »
Yep they are the Swift, says so here even: https://www.youtube.com/watch?v=2cYFIiRYwvk
adapt3Dprints.square.site
327 Short Banshee
BD417
Micro/Matrix hybrid Steambow
Franken360
nchunterkw
Re: Gold Tip Bolts
Post by nchunterkw »
Swifts are OK. I like the Nitro Pro line but they are heavy...13.9GPI. I see they have a SUPER FLY line now that boasts 0.001" straightnesss and is 8.5GPI
trinitystrings412@gmail.com
scratcherky
Re: Gold Tip Bolts
:thumbup: Hi, Sure appreciate the help. Don
Re: Gold Tip Bolts
Years back l was using the laser 2 with a 60 grain insert and a 150 grain boltcutter that was 210 up front and the heavy bolt the basically flew as accurate as a mechanical or field point.
Very accurate in the wind too for a fixed blade l killed 2 bear with that set up.
nchunterkw
Re: Gold Tip Bolts
I think those are GT Nitro Pros in my avatar pic. 125 gr Rancat on a 500gr total weight arrow went completely through a bison.
I found them to be not as accurate as Black Eagles, but their new Supe Fly offering might be worth a look.
I like a heavy arrow and it's tough to get with a Micro without doing shaft in a shaft stuff....so the Nitro PRO line at 13.9GPI helped a lot. I think their brass insert was only 60 so I added weights. SO tat was fine, and I got NuFletch to make me some smaller ID Igniters for that bison hunt.
