Thoughts on the Annihilator 150gr XL broadhead for a
Micro 308? At least I wouldn’t have to have heavier inserts going with a 150 gr vs a 125 gr.
Thanks Alan T
Broadhead Annihilator 150 gr XL
308 Short
Annihilator 150 gr XL.
Quill bolts with Beacon illuminated nocks.
Vixenmaster string.
Exocet 200.
Rage 2 blade broadheads.
Vixenmaster string.
Vixenmaster string.
Exocet 200.
Vixenmaster string.
Re: Broadhead Annihilator 150 gr XL
looks like a beast. Remains me of the old snuffer broadhead. You can lay that flat on a honing stone and then a barbers strap and you will shave hairs off your arm with it. Nice.
Lots of reviews on them all good.
308 Short
Vixenmaster string.
Exocet 200.
Vixenmaster string.
Vixenmaster string.
Exocet 200.
Vixenmaster string.
If your looking to pair a compact a well flying tough machined one piece steel fixed broadhead take a look at the US made and manufactured Tooth of the Arrow that offers a 150 grain in 4 versions, all featuring 4 blades which offer more cutting surface than a 3 blade.
TOTA 150 gr:
1" Solid and Vented
XL 1 3/16" Solid and Vented
Each pack includes at no extra cost is a broadhead wrench so you don't cut your fingers.
TOTA 150 gr:
1" Solid and Vented
- AJ01
And if you want something even bigger, TOTA makes a 175gr. 4-blade.
These heads are pretty tough. It requires a little more finesse to resharpen them.
The short overall length makes them fairly easy in terms of getting them to "fly right".
Tooth of The Arrow makes a sharpener designed for their head.
Lots of folks just use a flat file.
If you want something in the 200gr or bigger range, give VPA a look! They are a 3 blade. And tough!
And you can resharpen them on a flat stone.
These are the only fixed blades I'd recommend. I know there are several others on the market. But they just don't have the track record these two companies do when it comes to big, heavy-muscled game.
I ain't talking Whitetails here, I'm talking Elk and larger!!
