new maxpoints for sale
dw
Post by dw »
would any of you guys or gals be interested in one of these $375.00 U.S. funds plus shipping. 175lb 340 fps exact same bow as the paradox. comes just like you see it, brand new in the box. i have a chance to buy some of these , just want to see if there is any interest first. this takes the same scope mounting bracket and quiver mounting bracket as the excalibur recurves.
Smashing POWER! MaxPoint Crossbow has ZERO LET-OFF and stores 25-30% more energy than any modern bow!
Accelerate beyond the norm! It's easy with this MaxPoint Crossbow. It's a heavy hitter, producing 175 lbs. of raw power that zings your broadhead an amazing 340 F.P.S. with dead-on accuracy! The ZERO let-off MaxWing Cams are the muscle end of a 13 1/2" power stroke. When the cam reaches its draw force peak, it stays there, storing 25-35% more energy than any modern bow.
IBO is 340 F.P.S.
Machined 6061-F6 aluminum riser
Super strong arc carbon quad limbs
Right or left handed grip
Tech twist string length is 39 1/2"
Manual safety
Integral fiber optic sight and a built-in peep sight
Weighs 7 lbs.
Axle-to-axle length is 27 3/4".
thanks, dave wasserman
"you gotta love it"
Evan
Post by Evan »
These bows are really 3 bows in 1. Keep the compound limbs for a very powerful bow. Or bolt on standard limbs and you have an Exomag (185 pound draw wt version I believe). Or bolt on light limbs and you have an Exomag Light (about 150 pounds draw wt, same as the Vixen).
Evan
DOXNUT
Post by DOXNUT »
I'm not sure you'd get 185lbs by mounting straight limbs on the MAX/paradox rail. These bows have 13.5 in draw length............you have a machine with about the same specs as the vixen.
GaryL
Post by GaryL »
DOXNUT wrote:I'm not sure you'd get 185lbs by mounting straight limbs on the MAX/paradox rail. These bows have 13.5 in draw length............you have a machine with about the same specs as the vixen.
Yep with a 13.5" draw/power stroke would be closer to a Vixen.... :D
Always learning!!
Home fer now!
dw
Post by dw »
well i bought 4 of these. if any one is interested let me know. they are brand new in the box. i should have them friday. if no one is interested i will put them on ebay. they should sell well. same bow as the paradox. heck i might even keep one formyself. "dw" :D
"you gotta love it"
Digger
Post by Digger »
You need the prod and a 16" rail to convert the Paradox/Maxpoint to a Emag, it also cleans up the hole in the old rail.
Digger
Digger
2-1984 Relayer,
2-1992 Wolverine
Vixen, Steddy Eddy, Varizone
Martin Rage
Martin Jaguar
PSE Infinity
Evan
Post by Evan »
Sorry but you are mistaken. The 13.5" draw length is due to the compound limb setup being much longer than the recurve limb setup. I just measured my Vixen and my Maxpoint. On the Vixen the distance from the back of the riser to the latch is 15". On the Maxpoint the distance from the back of the riser to the latch (with recurve limbs mounted) is 17". The Maxpoint with recurve limbs is definitely no Vixen!
Evan
fletch
Post by fletch »
I think the recurve limbs should be longer than the compound limbs and when strung the stroke should be shorter using recurve limbs. Correct me if I am wrong.
Evan
Post by Evan »
Recurve limbs are wider than compound limbs, but compound limbs are considerably longer (because of the wheels and cable assembly) than recurve limbs. This means that for a given stock and rail assembly, the stroke is longer with the recurve limbs than the compound limbs. Even though the stroke of the Maxpoint/Paradox is considerably shorter than the recurve limbs, the ingenious design of the Maxpoint/Paradox allows it to reach maximum draw weight very early in the stroke compared to the recurve limbs, which is more linear.
dw
Post by dw »
3 left! :D
"dw"
"you gotta love it"
dw
Post by dw »
:D all gone. thanks to all that replied, dave wasserman
"you gotta love it"
DOXNUT
Post by DOXNUT »
To the guys who bought the "maxpoints"..................HAVE FUN! Be prepared to be blown away......
Evan
Post by Evan »
Maybe so. But the Maxpoint is all the crossbow you'll ever need for anything on this planet that you'd ever want to shoot with a crossbow. And show me another bow that's "3 bows in one". As I have said before, this bow is a tribute to the genius of Bill T, a true classic.
Evan
DOXNUT
Post by DOXNUT »
For sure! I own two.................Canadian models
GaryL
Post by GaryL »
Evan
Well your right on the Maxpoint 17" I reckon as I do not have one to measure and 17" with the Excalibur prod would be like a MAX. However my Vixen measures 14" from the back of the riser too the latch.... :D
Always learning!!
Home fer now!
